I need some more ram for cheap
My mid-2010 macbook is running kinda slow and i want to get some ram for cheap where is the cheapest ram? DDR3 ram
Your system is limited to 8GB and requires 204-pin PC3-8500 (1066MHz) DDR3 SO-DIMM (two slots)
このアンサーは役に立ちましたか?
ok were is the cheapest place i can buy this?
China... but you might not be happy with what you get...
You can check the businesses section and shop around, do a web search with the information Dan gave you or go here, duck duck go is your friend.
@bob boberson - You might want to look at upgrading the slow HDD this system has with a faster SSD which is what I would do if you are already at 8GB.
Just be careful! Your system is only a SATA II (3.0 Gb/s) one of the few SSD's that still support the older data rate is Samsung 870 EVO SSD
@danj i have already put a kinston a4 ssd in it also according to google i can use 16GB ram in my mac
@bob boberson - Sorry I looked up the wrong model the 2010 version can support 16GB
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 78
