メインコンテンツにスキップ
Googleの第3世代Pixelスマートフォンで、Googleの最先端カメラを搭載しながら低価格設定のモデルです。カラーバリエーションは、ジャストブラック、クリアリーホワイト、パープリッシュから選べます。2019年5月発売。
70回答 すべてを表示
Replaced screen and now it doesn't display anything.
Hello everyone,
I just replaced the broken screen on the Pixel 3a (not my first) and now it turns on, but the screen just flashes. I notice when I touch the power button the screen flashes and nothing else.
Could I have damaged the display pins? The original screen doesn't even work now.
Edit: Posted some photos of the display connector on the motherboard for reference.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
I had the same problem, I delicately bent the pins on the battery side outwards so that they made better contact with those of the screen, and incredibly it worked!!!
さんによる
コメントを追加
1 件の回答
ベストアンサー
Unfortunately, it would seem that you have damaged the connector on the main board. For microsoldering repairs, @flannelist may be able to help you further.
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
I figured as much, so now the next thing I would like to ask is there any way I can extract the data from this phone?
Google assitant is turned off, USB debug is also off, and I only have the fingerprint button, power button, and volume keys.
さんによる
@troubleshot If you happen to have Google cloud backup turned on, you can get that. Otherwise, you could desolder the storage chip from the main board and solder it to a known working Pixel 3a
さんによる
Unfortunately I had it turned off because it got full. Is there someone here familiar with microchips to see whether or not the connection is damaged.
I can get close enough with one of my better cameras. I just ordered a new screen I think it was a defect because it just flickers when I push some buttons or the screen changes to a different one. Worst case scenario I will take it to a microsolder.
さんによる
@troubleshot I'm not that well-versed on microsoldering, but @flannelist may be able to help.
さんによる
Thank you very much for your help. I'll try to reach @flannelist.
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
F G さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 30
今までの合計 450
