How to change rear battery cover?
I want to change the rear battery panel because it's got some using marks and looks really bad
ybo.shooter check this video you need a heat gun as your main tool. Temperature on the back cover should be around 70deg C to loosen the adhesive. Not complicated just a bit tedious.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 467
