How do I fix the seat belt ribbon?
Seat belt is not being pulled back in
If its not pulling in at all I would think it needs to be replaced. The mechanism is a complex little part that can even have a small charge that fires with the air bag to tighten the belt a little.
When you pull the belt all they way out dose it make the typical seat belt noise? Then its just all out sitting there with zero tension?
I had a belt that would retract slow or only 90% of the way; I washed the belt in hot water to make it more flexible, that helped a lot.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 9
今までの合計 92
