beats studio wireless not charging
they charged good. then they needed a specific placement. now they dont charge at all. help pls?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It's most likely the charger or the port on the headset that's worn or being filled up with dust, making it have a bad connection.
I would start with really carefully cleaning the charger port on the headset, start with turning the headset off and then carefully trying to get the dust out using some type of needle or something else that's thin.
Then I would try using another charger, the headset seems to be using a micro USB charger. Not too long ago all Android phones used this kind of charger, and most other small electronics still use this port as well. So you probably have one available at home to try out.
If it doesn't work with another charger, it's probably the charger port on the headset that is bad and would need a replacement. I can't really say if it would be easy or not to replace this. But come back if this seems to be the problem and someone will try and help you solve that!
Good luck and hope this helped! :D
このアンサーは役に立ちましたか?
hugoeih this "then they needed a specific placement." could be caused by a bad cable or a bad connector. I suggest you try a different cable first. If that does not help you will need to replace the connector. Something like this video or this writeup should get you into your headphones to replace it. Of course, it is soldered to the board so it might make things a bit more complicated.
このアンサーは役に立ちましたか?
what is a connector?
thanks
It is the female plug where the cable connects to.
過去 24時間: 11
過去 7 日: 65
過去 30 日: 279
今までの合計 1,795
1件のコメント
hmm i changed charger and it doesnt charge. now will try to clean the thing
hugoeih さんによる
