メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Mitsubishi Electricによる製造が終了した、Mitsubishi製テレビの修理ガイドとサポート情報。
Where do I find firmware for my TV?
I just purchased a Mitsubishi WD-82738 82" DLP 3D TV and seems has never been updated once. I need a firmware update of 12.7 or higher to enable 3d enhancement features and 1.4a hdmi protocols so I can use it with modern 3d players like ps3 or 3d blu-ray players but Mitsubishi discontinued their sales and firmware downloads and I can't find it anywhere.. Help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
https://www.mitsubishi-tv.com/contact-us...
Try contacting Mitsubishi's customer support. If that TV has an available update, it's possible that they will provide it.
さんによる
Thanks Funk gave it a shot but they have no idea how to help. They have not had access to any firmware or support to their TV's for a decade, even the 4 TV Mitsubishi certified repair shop numbers they gave me were all disconnected.
さんによる
コメントを追加
1 件の回答
ベストアンサー
You can try to find what you need by searching in the internet archive wayback machine, if you're lucky the download you need will be archived here's a link to get you in the ballpark: https://web.archive.org/web/2011*/www.mi...
Adrian ok, I won't be lazy.. . But all you needed to do was search the archive until you found this link
https://web.archive.org/web/201012212238...
Instructions. Are here
http://www.mitsubishi-tv.com/3Dupgrade_i...
New operating instructions are here
https://web.archive.org/web/201105211435...
I WAS too lazy to keep searching for a later upgrade, if any...
Anyone else with the same problem but different model
(WD-60738, WD-65738, WD-73738, WD-82738, WD-65838, WD-73838, WD-82838 only)
go here instead
http://www.mitsubishi-tv.com/3Dupgrade.h...
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Juan, you are the Man! I was giving up hope and was going to spend $200 on a 3D converter kit. Now, a seemingly common issue as I see through old forms, why the TV won't read the USB drive lol
さんによる
@Adrian Freelancer Awesome! You should link it here if possible. Thanks!
さんによる
If it can't read your thumbdrive try an older, slower, smaller cheaper one, a geriatric tv needs a geriatric usb stick. Look in the manual to see what it can read.
さんによる
Before you ask your manual is here
https://www.manualslib.com/products/Mits...
If you are feeling grateful send part of that $200 you saved to the internet archive or right to repair both of which were instrumentals in your salivation LOL.
さんによる
I hate spell checkers!
さんによる
コメントを追加
回答を追加する
Adrian Freelancer さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 35
今までの合計 2,453
