Can a discharged phone battery combust
So I want to replace my iPhone 6’s battery which is completely discharged so can the battery combust if punctured or cut by mistake?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi
Yes a battery can combust if it is fully discharged but it isn’t as dangerous if it is
I wouldn’t let this bother you though because as long as you are using plastic tools it’s very hard todo so
Thanks
このアンサーは役に立ちましたか?
Yes, it can burst in any situation even discharge. Battery blasts when it got a chemical reaction between both the terminal and diode panel. Positive(+) and negative(-) points meet and create a short circuit.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 39
