メインコンテンツにスキップ
My ps4 pro won't boot
my ps4 pro won't turn on, the light bar lights up blue for 1 second then it shuts off instantly no white light or even breathing blue. The Disk drive and fans don't spin. When i try to turn it on for a second time the light bar doesn't light up but the console beeps and it shuts off instantly again
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
So from what I can tell the issue might be with the Power Supply Unit, but I want to eliminate any external factors before encouraging you to swap it out. Make sure that there is nothing wrong with the outlet that your device is plugged into, and ensure that the cable connecting your console to the outlet is not damaged.
Once we make sure that the issue is internal, you can use this guide to swap out the PSU.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
sherouzan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 213
