メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
iPhone 6 Plus - pulls charge, but no boot
I have an iPhone 6 plus with water damage, it pulls .5A (it drops to .01 every few seconds then back up) but doesn't boot. I cleaned the board and checked for shorts and found nothing. I'm fairly new to board level repairs, so I'm mainly looking for what steps I should take from this point to narrow down the fault
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント
If you are new to board repair the first rule is to rule out a parts issue.
さんによる
@imicrosoldering The first thing I did was removed board and used new battery, new screen, and new charging port. It's definitely a board issue, just not sure the next steps to take when there's no short. I hooked up battery and tested voltage throughout the board, got 3.7 throughout the main power rail, where should I look next? I also replaced tristar which didn't resolve anything, which I expected since it already pulls a charge. Also plugged into pc to see if it was booting to dfu, but that was a no go as well
さんによる
@shadowsuave Have you tried an update with iTunes?
さんによる
@imicrosoldering it's not detected by iTunes
さんによる
@shadowsuave You will need to put the phone into recovery mode or if data is not important DFU mode.
さんによる
コメントを追加
2件の回答
最も参考になった回答
First thing I would do is check for any components that look out of sorts. Where did the liquid go? Does anything LOOK damaged. With any sort of known damage, your eyes are going to be your best clues. Even if you can't see anything amiss, the areas where the liquid went are probably where you're going to find fault. Even with a good ultrasonic cleaner, corrosion under chips isn't necessarily going to get cleaned up.
I don't think Tigris, or elements of the charging mechanism are a bad idea, assuming there was corrosion there.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
hello Lenny,
a similar pulsating behaviorism is a symptom of a faulty main charger and its switching transistor. If you plan to fix it yourself, these two ics should be replaced. It looks like a reverse polarity connected current to me, as if someone made a mistake when trying to repair. It happens sometimes. If you prefer to have such a repair done, find a good repair shop, remove the motherboard and bring it back. Order replacement of the TI SN2400B0, DRV2604YZF and CSD68815W15 transistor. The components cost half a dollar each and soldering these little ones shouldn't be too expensive either. However, this does not exclude other post-flooding problems that will also need to be resolved.
t
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Okay, so it sounds like my head was in the right place cause I ordered 2 out of 3 of those components yesterday. I got Tigris and the charging mosfet and will be replacing both of those today, if that doesn't work I will order the other component and try that as well. And I'm not too worried about resolving other issues as this is data recovery only, thank you for the reply!
さんによる
コメントを追加
回答を追加する
Lenny さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 101
