メインコンテンツにスキップ
Why is my laptop's fan is very loud?
We all know that asus tuf has three category of performance silent, balance and turbo. So, last time usually when i set my laptop in balance mode the fan is not so loud and noisy but this day it become more loud and noisy. I have try clean the fan but it still not working..pls help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
What is your CPU fan temperature at?
さんによる
Try limiting cpu clock speed in bios, or maybe going into windows power management
さんによる
コメントを追加
3件の回答
最も参考になった回答
Try installing Park control and see what power profile the computer uses while in balanced mode. It usually uses High performance, try change the profile to Balanced or AMD Balanced and see if that might lower the fan speed ergo the noise.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hello,
I had the same problem(fx705dt model). Firstly I thought I will have to replace the fans because I owned it about 3-4 years. I did and for some period of time it worked. About 2 days ago, it started again and I searched on youtube etc. I saw someone saying that if you change gradually from Silent mode to Performance and Turbo it will fix the case (this specific person told that he did that for a period of time and now his fans are fixxed, tbh it's something you can do for now, but I am warning you that my fans were replaced and still had the same problem, so I am gonna try this solution.)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi,
I think your laptops fans speed is very fast thats why it sounds loud.
I have found an article how to change laptops fan speed, I hope it will help you.
Thanks.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Musyrif Muaaz さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 40
過去 30 日: 206
今までの合計 12,456
