Can I use the se 2022 battery as a replacement?
Can I change the battery of the se 2020 with the bigger battery of the se 2022?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I cannot state this for a fact, but generally speaking, iPhones across generations do not use the same battery connector. The original SE and the 5S for example, do not use the same battery connector, even though the chassis and many other components were the same. The 8 and the 2nd gen SE, also do not use the same battery connector.
I suspect this is the same for the SE 2nd and 3rd gen SEs as well.
このアンサーは役に立ちましたか?
Hi
Don’t quote me on this but I remember seeing in a taredown that the SE2022 has a bigger battery so I probably won’t fit
過去 24時間: 5
過去 7 日: 12
過去 30 日: 44
今までの合計 1,354
