メインコンテンツにスキップ
The sixth generation Maxima, code-named A34, was only sold in the United States, Canada and Mexico. It was introduced in production form as a 2004 model at the 2003 North American International Auto Show.
25回答 すべてを表示
Car Won’t Start And Turn Over , Fans Run & Battery Drain
My Nissan Maxima Isn’t Turning Over When I Try To Start It , It Gives A Crank But Isn’t Turning Over , My Fans Constantly Run And My Battery Drains Out Within Mins. Was Told It’s My ECM But I’ve Order A Programmed One And Installed It And Still Having The Same Issue. Checked All Fuses And They Were Good. Car Isn’t In A Fail Safe Mode , Security Light Flashes And Isn’t Solid. After A Well The Fans Shut Off And A Clicking Sound Comes From The IPBM Fuse Box.
I’ve Been Reading All Over And Have Seen Different Answers With Checking ECM Relay & Things Of That Nature. I Truly Spent Days On It Myself Changing Fuses And Again Even Replacing My ECM. I’m In Desperate Help. If Anyone Truly Had This Issue I’ll Take Text/Calls 267-579-7719. Dealership Is Quoting Me $2300
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@damedolla24 Ok so there are three things that make an engine start: fuel, air (compression), and spark. If one of these isn’t there then the engine won’t turn over. Check for a bad spark plug or a faulty distributor. A way to check the fuel pump is to turn the key to the ACC position and listen for a whirring sound from the back, which lets you know it’s working.
The security light flashing sounds normal. Most cars do this when they’re locked and the anti-theft system is armed.
Also which fans are you talking about? The engine fans or your climate control?
The battery draining within minutes could also be an issue. How old is the battery? If it’s more than 4-5 years old, you probably need to replace it.
Best of luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dame さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 19
今までの合計 582
