メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
1199回答 すべてを表示
Is it possible to buy just the OLED panel? Or not?
Hey guys,
Getting into iPhone oled screen restorations but found that I can buy all the bits (glass, digitiser, polariser, oca, frame etc) except for the actual bit that gives image and picture (oled panel).
Can someone that does it tell me if it’s not able to be purchased? Issue I’m having is some screens I have are showing green or white lines running up and down, normally either white or green, or the oled shows no image at all. Spent hours searching the net and union and Rewa but none of them have it, just the oled panel.
That is why I ask if it’s actually possible to do and buy.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
so what your saying is you want to build screens instead of refurbishing screens with good oled panels, just seems a waste of time researching this, the only option is refurbishing good oleds with broken glass, in that case you will need a heater to cut the old glass off, a laminator and autoclave or you could go for an all in 1 like the ak pro.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Hi Daniel, Thanks for your reply. I'm asking because I have about 20 screens here and some of them not only have cracked glass but also green line through the screen (faulty oled panel). Thats why I'm asking if it's possible to change out that part just like the glass or polarizer and other stuff. But i'm guessing now seeing as though no one has it it's not a part that can be changed.
When I pull the screens apart I have to have a look under the microscope if there is any flex damage, or if I can find the reason why those lines are there. There a a few screens too that do not turn on at all.
I just thought I could fix them all.
さんによる
コメントを追加
I bought all that stuff a couple years ago but ultimately gave up because of the various problems like this and it’s time so time consuming.
It only makes economic sense in the latest iPhone model because the screens are going to be super expensive, but on the downside not many people are getting the latest iPhone model fixed.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
i dont even do screen replacements, charge port or battery replacements anymore to much hassle of other people undercutting prices, theres only 2 people in my town that deals in microsoldering work and im 1 of them so decided to do more of that type of work
さんによる
コメントを追加
回答を追加する
Tommy Duris さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 105
