メインコンテンツにスキップ
Sony Computer Entertainmentによって製造されたTV用ゲームコンソールです。PlayStation 4 Slim (CUH-2000シリーズ)はSP4の薄型モデルです。2016年9月7日に発売されました。
566回答 すべてを表示
Why won't it let me play my ps4
My ps4 slim was powered off and unplugged when iuged it back it it said I needed a usb update for the current version I tried doing te first couple google searches and it came to not help me at all I'd really appreciate any kind of help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Can you take a picture of the error and upload it here? iFixitでの質問に画像を追加する方法
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi Jake!
Please check the official Sony website for more info: https://www.playstation.com/en-us/suppor...
You are able to download 2 files there.
1: The update file, which can restore it if it's stuck, or just for updating the PS4.
2: The reinstallation file, this one is meant if the update file is not working or if you want do a "factory reset", or if you replaced the hard drive. Note: All the current stored local data will be wiped.
Some additional info: Your USB drive needs to be formatted to FAT32. And the folder structure goes as: PS4 (folder) > UPDATE (folder) > PS4UPDATE.PUP (file). It's also explained at the Playstation website added to this post.
I recommend to try the update file first, if it still wont go further or is giving errors, please proceed with the reinstallation file. If this one is still stopping the PS4 from booting to the menu, or if this one is also giving errors, you probably need to replace the hard disk.
Replacing the hard disk is easy to do, and you don't need to disassemble your PS4. If the HDD is broken, I suggest to upgrade to a SSD.
Good luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jake Byrd さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 9
今までの合計 722
