Late 2014 iMac 27inch retina. Switching one when mains power applied.
Hello all,
I have had my iMac, from new, since early 2015 and have never had this problem until recently.
The problem is as follows:
I have always shut my iMac down completely then switched off the mains supply to the computer, this has never been an issue.
However, of late when I come to switch the iMac on by first switching on the mains power, the imac will switch itself on without the power button being pushed.
Also, If, on occasion it does not switch it's self on (about 1 in 10 times) the start up tone does not sound until 20 -30 seconds after the power button is pushed. Then it will start the boot up process.
As I say I have had no issues at all with this computer until the last 2 - 3 weeks.
I have done all the resets recommend and completely clean install of the latest version of Big Sur, None of this as made any difference.
The Mac spec is:
iMac (Retina 5K, 27-inch, Late 2014)
4 GHz Quad-Core Intel Core i7
32 GB 1600 MHz DDR3
AMD Radeon R9 M295X 4 GB
Thanks in advance for any advice offered.
Regards
David
この質問は役に立ちましたか?
