メインコンテンツにスキップ
Also sold under the GMC Sierra and VIA Vtrux names, available in the US, Canada, Mexico and other countries around the world.
80回答 すべてを表示
Had the starter replaced, now RPMs slightly jump?
2003 Chevy Silverado 4x4 5.3 V8 . I just had my starter replaced. Once I picked up the truck from the shop, waiting to pull out I noticed the RPMS were low and the needle was jumping a bit. The truck seemed to run a little more rough while idling. It never stalled but at one point acted like it was about to. I’m not the most knowledgeable with this issue and wanted to see if anyone had any thoughts as to what is causing this? Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント:
My 1994 suburban was doing that. I replaced plugs n wires and that significantly improved this. Also, if it sat a while, run some seafoam through to help clean the fuel system.
さんによる
@brandon_k thanks! It hasn’t sat due to this being my daily driver. I noticed yesterday after driving it for 10ish min that the rough idle seemed to be gone. I haven’t drove yet today but we will see. I’ll look into replacing the plugs n wires!
さんによる
@newbie I definitely would. Like I said mine acted exactly like that. Almost stalled out a few times but not quite. After replacing plugs n wires, it stopped bouncing the rpms around, other than very minor fluctuations every now and then.
さんによる
コメントを追加
1 件の回答
A starter replacement will not cause a rough idle.
But if it sat for a long time b4 you had the tarter replaced, that may have resulted in clogging of the injectors or another fuel delivery issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Adelma さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 69
