Why won't my craftsman hydrostatic riding mower ,
Won't move forward or reverse but when you lift the rear end the tires turn
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Heidi, I am thinking it could be one of two things; you need to push back in a bar in the back that disengages the transmission, or, and more likely, you may not have gotten the pin or key back in when when you fixed the flat tire. Did you see a little pin that slides in along the axle?
This video may help: https://www.youtube.com/watch?v=YC4LnrfE...
このアンサーは役に立ちましたか?
Thank you, yes it was missing key in the tire, ...had to make one but all good now. Thanks again
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 90
3 件のコメント
Is there any leaks?
Duck さんによる
No,..
I parked it, wouldn't start,...was starter solenoid....went to go and nothing ..but when lift rear the tires will thrn
Heidi Edgmon さんによる
Only other thing I did was fix a flat tire ...
Heidi Edgmon さんによる
