MacBook optical drive in iBook
Can I replace iBook G4's optical drive with one from MacBook (A1181)?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
MacBook drives use the same PATA interface until the Early/Mid 2009 models.
Regardless, iBooks use a full-sized drive, and the MacBooks use slimline drives, so they are not compatible. Sorry!
このアンサーは役に立ちましたか?
They're definitely not inter- changeable. The iBook uses Pata connector and the A1181 uses a sata interface.
このアンサーは役に立ちましたか?
Are you thinking of hard drives? The A1181 uses the same interface until Early 2009 models.
You're right Ben, good eye!!! I was thinking hard drives. Thanks for the pull_up!!
As you can see here, I don't believe that the drives are interchangeable.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,109
1件のコメント
If one of these answers fixed your problem please hit the "accept" in list that has "History Edit Flag Accept Comment" located to the upper right of your question so we can remove it form the unanswered list.
mayer さんによる
