メインコンテンツにスキップ
Apple Watch Series 1はオリジナルのApple Watchの改良版で、2016年9月7日に発表されました。 パーツの多くはSeries 2と同じです。
124回答 すべてを表示
boot loop apple watch series 0 sport. on both charger & off
I have a issue on a series 0 sport which is basically a series 1. I did a battery replacement from a totally dead battery. The new one gets past the snake charge screen so the battery got initialized but now it boot loops. logo 3 seconds power off. repeat every 5 min or so. force reset doesn't fix it. do you think battery isn't good? not enough voltage? no damage to the gasket touch sensor that I can see. left it on charger for 3 days so far to no help. I unplugged the battery for a day to ensure it had no power and it didn’t help. I get the boot loop on and off the charger so the battery has some power at least. It never charged more than 2.2w according to my kill a watt meter and it did this in a weird way. 7 seconds charge 5 seconds no charge. it now shows 1.3w now with same same cycling. could this new battery be bad? never seen this before.
Update (03/20/2022)
Here is what it does one charger or off the charger. Reset doesn't help but does attempt to reboot fast than the 5min cycle
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
You really want to have a look at those two other questions with the same issue:
Apple watch stuck in a boot loop
Apple watch original boot looping on the charger
Both point to the battery as being the likely issue. The latter link points to the battery replacement guide.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
stressmaster さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 339
