Unable to turn Sony Ericsson Satio on despite being fully charged
i have a sony ericsson satio and the problem is I can't on it. It first started when i left my phone overnight to charge and the next day it was dead
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I'd start off by removing the battery and cleaning the connectors on the battery and the phone. Use some isopropyl alcohol to clean. Also make sure that there is not debris on the connectors and that they actually make a connection. If you can take a multimeter and check on your battery to make sure it is truly charged, or you could borrow a battery to see if that makes a difference.
このアンサーは役に立ちましたか?
i tried using newer battery still no results but when i connect to my computer it flashes red on the led and i send it to a phone repair shop for check apparently my motherboard of the phone is spoilt..
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,054
