メインコンテンツにスキップ
The Town & Country was redesigned for the 2001 model-year, using the Chrysler RS platform and initially only available in long-wheelbase (LWB) form.
25回答 すべてを表示
Why won't my turn signal work?
Recently my front driver side turn signal bulb went out. It did the thing where it started blinking rapidly, suggesting the bulb was getting bad, but then it quickly stopped working altogether.
I took it to a mechanic who put a new bulb in, which also didn't work. He tried both the old bulb and the new bulb in the other turn signal bulb sockets, and both bulbs worked in them.
The mechanic said he tested the fuses and wire harness, and didn't find any issues there, and said I may need a new computer chip. Any ideas what else it could be?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@amfarrell this is one of those cases where your mechanic may actually be right. there are no more relay, the blinker is controlled by the BCM. If the wiring/connection/bulbs/fuses are okay and he has checked the Multi Function Switch (blinker switch) then it is either the BCM or the IPM.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks for the reply! It wasn't what I wanted to hear, but I feel more comfortable with my mechanic's report now that I have this second opinion. Thanks again!
さんによる
コメントを追加
回答を追加する
Austin Farrell さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 19
今までの合計 193
