メインコンテンツにスキップ
The Dodge Avenger name returned in February 2007 as a 2008 model year sedan to replace the Dodge Stratus, whose coupe version had replaced the original Avenger in 2001.
8回答 すべてを表示
Driver side Rear wheel slants inward on top.
So the vehicle was in an accident where it got hit just above the rear driver side wheel. The wheel also took damage and now when car put into drive the top of the wheel slants inwards, when car put into reverse the wheel straightens up almost perfectly. I have replaced bushing and control arms that connect to the knuckle and still get same result. Please if anybody has had this happen to them before I will really appreciate the advice on how to fix. Please Help...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
選択されたソリューション
RUDY ALVAREZ that is usually caused by a bend control arm or spindle. Since it was in an accident, check all suspension parts and there may be a possibility that this is caused by a bend frame. A good body shop can help you out with checking that for you.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Yeah I have checked suspension parts and replaced bushings and control arms, people have mentioned the bearings but when jacked up wheel is solid and don't hear no noise coming from bearings. I haven't really drove the car since the wheel scrapes the spring that's around the strut. Do you know if I go to a shop where they do alignments, will they be able to pinpoint the problem? Or does it have to be a body shop?
さんによる
Thanks for taking your time to answer my questions, and I really do appreciate your advice.👍
さんによる
Rudy Alvarez good alignment shop can see it as well. Those guys are usually really good about letting you know whats going on. Really hope it'll work out for you
さんによる
コメントを追加
回答を追加する
RUDY ALVAREZ さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 18
今までの合計 159
