Can I hook up dvd/vcr player to RT3205-E?
How do I hook up Toshiba DVD/VCR to RT3205-E. Do I need HDMI converter?
narnyfr your TV appears to have HDMI X2, RF, YPBPR, AV AUDIO/VIDEO inputs. One of theses should fit your DVD/VCR. If unsure post some picture that shows the connections on your TV. Should be the same idea as listed in this manual Once the Toshiba is connected you will have to use your TV’s remote to turn it to whatever input connection you have chosen. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
Okay, I hooked up, I have picture no sound?
narnyfr
post a picture so we can see how you have it hooked up. Check your TV settings to make sure your audio is properly setup as well.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 53
