メインコンテンツにスキップ
Microsoftの第7世代Surface Proのビジネスモデル用のリペアガイドです。Surface Pro 7+は2021年9月22日に一般ユーザー向けにデビューしました。
11回答 すべてを表示
Surface type cover not powering on and connecting to the computer
So…I currently use a surface pro 7+ for everyday and all of a sudden my keyboard stopped working (For context here’s a few things that are normal):
  • Surface turns on
  • Surface reaches login screen
  • Surface logs in and is on home screen
  • Surface is in UEFI bios
  • Surface is in Advanced startup options.
In none of these scenarios does the keyboard work. No lights are on. No signs of life. However after a reset of windows it does work but then small things do trigger it to stop working again.
I have tried literally everything from cleaning the contacts to even (repeatedly) turn on and off the type cover port in the UEFI bios with absolutely 0 luck at all.
Pls help as this is a machine used on an everyday basis.
Thanks.
Update (10/04/23)
So, after going back and forth with Microsoft, the only solution they had was to send me a new keyboard, which now works fine.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Plugin the external keyboard to check whether the fault is in the keyboard or something else. As you said after windows reset it works, which means there might be some software glitch. Try to update or restore the updated driver for the keyboard. Sometimes keyboard gets turned off from bios too. You should also check from there.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Unfortunately I did try all of those and none of it worked. It happens at random and the only real way to fix it is to reset the whole device
さんによる
@np_f1_2021 It might possible there is some virus that stops or turn it off. It happened to me a long time before. After reset doesn't open any drive. First Install and scan the whole PC with a good Antivirus.
さんによる
Funny thing is it happens when the following occurs (so far):
A monitor is connected (my personal one is a Dell S2722QC type c monitor)
My specific wireless keyboard (Mx keys mini for Mac because I also use a Mac and bought the keyboard without windows pc in mind lol) is connected
And probably more to come
さんによる
And then it never returns until the pc is reset
さんによる
コメントを追加
La mia tastiera funziona su altri ma sul mio Surface pro non funziona più
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Il bios UEFI blocca la type cover port
さんによる
コメントを追加
回答を追加する
Nick P さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 22
過去 30 日: 87
今までの合計 2,292
