メインコンテンツにスキップ
The Xtreme 3 from JBL is a Bluetooth-powered speaker, and is the 3rd generation of the Xtreme series of speakers.
7回答 すべてを表示
My xtreme 3 won't charge
I brought a jbl xtreme 3 2 weeks ago the battery has died and I can't get it to charge. I plug it in and it just turns back off
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
Hello Katie, plug it into the computer , as if the computer would be charging it , open your options for external discs, find the device , go into the settings if possible, or if not possible , eject the device with options from the computer. then it should work, unless the battery is dislodged, then it’s a lot more complicated.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My boombox is completely dead and I can't get it to charge. I thought they when it was dead just plug it in
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I found the issue on my end. Check the charging board to see if the ribbon cable is connected or if it has a break. If the ribbon cable is not connected, the box won't have charging logic and won't be able to check the battery status. If that doesn't solve the problem, the battery is probably defective.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Katie さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 48
今までの合計 1,411
