How to take a broken headphone jack out of the headphone slot?
My friend broke his headphone jack in the headphone slot, soo how do you take a broken headphone jack out of the headphone slot?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi Ben,
That situation happens often enough that they've designed a tool specifically for that job. Although you can find them many places like Amazon and eBay, you can support iFixit's repair efforts by buying it right here.
このアンサーは役に立ちましたか?
Thanks, but I already took it apart.
@nytryder26 you might be able to open it and push the broken pin out from the top of the connector
このアンサーは役に立ちましたか?
Are you willing to replace the headphone jack? If so, follow the dissasembly guide. Screw off the back motherboard after everything is taken apart, and then you should be able to just take the headphone jack out and put the new one in. They are loose, so no soldering required.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 9
過去 30 日: 53
今までの合計 1,004
3 件のコメント
are you confident enough to open the controller?
Logixal さんによる
@logixal If I have to open the controller, sure.
NR26 さんによる
@logixal Ok thanks
NR26 さんによる
