メインコンテンツにスキップ
Lenovo YOGA 730-15IKBは、専用グラフィックスと高解像度タッチスクリーンを備えた15インチの折りたたみ式ラップトップです。2018年に発売されました。モデル番号81CU0009US。
10回答 すべてを表示
Lenovo doesn't go to sleep when lid is closed.
I recently changed the the back cover of my screen because it was worn out, and since then, my laptop doesn’t go to sleep when I close the lid. I assume that I lost the lid cover magnets/sensors. Is that correct?
If so; Is there any way I can buy these magnets/sensors?
Thanks, Jorge
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi @jorsouto ,
Have you checked if the original lid still has a magnet installed that you could use? Perhaps it is supposed to be integrated in the lid all the time and the replacement didn’t have one. Just a thought as I don’t know if this is correct or not
Have you verified that it is a missing/moved/loose magnet that is the problem?
Check the lid switch settings to make sure that they’re OK.
Slowly run a magnet around the top outside edge of the keyboard/upper case assembly and check if the switch operates and places the laptop into sleep mode or at least turns off the display.
Here is an image of what the magnetic switch looks like, along with its designation (UHST) on the systemboard. So if you locate the switch by using the magnet around the upper case assembly, the lid magnet should be in a corresponding location in the lid. If you can’t find it using a magnet you may have to open the laptop and find the switch.
(click on image to enlarge).
Here’s the hardware maintenance manual for the laptop, that may also help with the dis-assembly as well
Just some things that I’d try
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Am also facing this in multiple laptops ... mostly after installing latest windows updates or lenovo vantage causing this issue...
this is not hardware issue...
can someone fix this
さんによる
Hi @onedollars52860
Have you checked that all the "lid switch settings" as shown in the link in the answer above are what you want?
さんによる
thank you so mutch it really help as the new chassis doesn't have the magnet in it , so i took it from original one and now its perfectly working .
さんによる
コメントを追加
回答を追加する
Jorge M Souto さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 88
今までの合計 6,212
