Power keeps going off within 3 minutes of starting, why?
Power & picture keep going off with red power button blinking
Hi @don56,
Check if the red power button LED is blinking an error code. It will blink in a pattern that is repeated 5 times e.g. a 34 error code is 3 blinks > pause > 4 blinks > pause > 3 blinks > pause > 4 blinks > pause etc.
Here’s an image showing the meaning of the error codes for some Mitsubishi TVs. Hopefully your model is included. The model numbers are at the top of the page in the image.
(click on image to enlarge)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 58
3 件のコメント
@don56 when and how long after can you turn it back on? what have you checked? Your TV is a MITSUBISHI WD-73C9 ?
oldturkey03 さんによる
Yes I do have red light
Louise Tv さんによる
What do I do fix my TV tha nk you
Louise Tv さんによる
