メインコンテンツにスキップ
Repair guides and troubleshooting for the Whirlpool Quiet Partner II insulated dishwasher.
39回答 すべてを表示
Drain pump Won't work when hot
Maytag dishwasher mdb4949sdh3.
Will not drain rinse water at the end of a cycle. It won't drain or start a new cycle until it sits a couple hours. Once it sits, I can drain it. It will also start a new cycle.
It drains wash water great. It will drain the rinse water great AFTER it sits. Impeller works. No clogs. Its like something is getting hot and needs to cool off before the pump will work again.
Has anyone actually FIXED this SAME issue?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Hi @sonnyjunebug,
Here’s the tech sheet for the dishwasher.
Try running the diagnostic tests as described in the tech sheet and check for any error codes etc.
If no codes then run the DW as per normal and when it doesn’t drain, disconnect the power and disconnect the harness from the drain motor and measure the drain pump motor resistance to check if it is within specs i.e. 15Ω-60Ω across pin1 and pin 3 of motor in case it is breaking down due to the current flowing through it.
If the drain pump is faulty search online for WPW10348269 to find suppliers that suit you.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
@jayeff you are a godsend. I ran the diagnostics. The dishwasher was not level.
Forgive me for taking so long to thank you. But, I wanted to run the dishwasher several times before updating the post. It works like new!
I still think it is strange that it drained the wash water ok and wouldn't drain at all when hot. Maybe running the diagnostics reset it somehow. (I had tried to reset it by cutting power before).
さんによる
@sonnyjunebug
I think that not being level may have had more to do with the problem than the dishwasher just requiring a reset.
Hopefully it was the cause of the problem and that you have no more troubles with it.
Cheers
さんによる
コメントを追加
回答を追加する
Tina さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 36
今までの合計 384
