メインコンテンツにスキップ
Huawei Mate10の修理ガイドです。
17回答 すべてを表示
Slight crack in a Huawei Mate 10's screen, what is best to do?
I noticed today that my Huawei Mate 10 Lite’s screen is slightly cracked at the edge after I hastily put it in my pocket yesterday (I usually carry phones in my backpack) and then proceeded to run around with the same phone in my pocket. The resulting damage can be seen on the picture below, and I am not exactly sure what to do. I am not very concerned with looks, but I am worried about small pieces of glass falling out. At the same time, I am not sure if something as drastic as screen replacement is necessary. Is there any way to hold the small piece at the crack together so I don’t have to put out money on more expensive repairs? What sort of thing would the other fixers recommend in this case?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Most of the time those cracks never spread far if you’re careful, but the catch is if you handle it rough while you use it then they tend to spread quickly.
However, you need to worry more about the LCD. Thankfully this is a common IPS LCD, not AMOLED. If it was AMOLED, you'd need to be extra careful or you would be replacing the screen. As long as the LCD doesn’t look funny, I would live with it unless you see evidence of hidden damage that’s spreading.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
E. V. さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 111
