メインコンテンツにスキップ
2017年11月4日に発売。モデル番号はA1865, A1901です。GSMか CDMA / 64か256 GB/カラーはシルバーかスペースグレー
1013回答 すべてを表示
iPhone X home bar not working
Anyone experience an iPhone x or later home bar not working correctly? It works for awhile then it stops responding and swiping up (the screen itself is still working). It doesn’t seem like it would be a hardware problem since its not an actual button. Its just weird cause a restart doesn’t fix it. a restore temporarily does.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I’ve had this with some customer phones, of which it always being hardware or software. The fact that restarting the phone temporarily solves could point to both but mostly software. I’d say to rule out your screen try drawing with notes or Snapchat to ensure there is touch down at the bottom, and that it seems to work seamlessly when doing so. (You could try this after a fresh restart to temporarily rule out the software thing.)
If that all looks good then I’d recommend creating a backup, resetting the phone through DFU mode and temporarily setting it up as new. Sometimes some software bugs can carry over with iCloud data. If you have a screen replacement handy you can try that too as thats a pretty quick way to rule out hardware.
Good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
CAB さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 16
