Why isn't my ac cigarette lighter outlet not working.
my cigarette lighter isn’t working, I checked the fuse box but the fuse was still good.
@srw23 the only thing between the cigarette lighter and the power is the fuse. Since the fuse is still good, check the wiring to the outlet and check the see if the outlet receives power. Use a test light or a meter and trace the wiring. You did not tell us which year your Explorer is but check fuse #24 in the instrument panel fuse box and fuse #7 and #9 in the fuse box in your engine compartment.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 15
今までの合計 408
