Home mini fell & not powering on since No loose connection internally
I’ve opened up … can’t see anything obvious - time for bin or any other ideas ? Thanks
Hi,
Have you checked that the power supply to the device is still OK i.e. that there is +5V DC on the output plug of the supply, you didn't say?
Connect another suitable adapter i.e. output voltage = +5V DC @ 2A (2000mA) and has a micro USB plug and see if it still works. Some phone chargers may be suitable. Check the specs which are usually printed on the adapter case..
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 40
