メインコンテンツにスキップ
Released March 2019, identified by model number SM-A305FZRFINS
36回答 すべてを表示
Why does my A30 just keep switching on and off to the Samsung logo
Why is my A30 stuck in a loop.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント:
Hello.
Have you tried to force your phone to reboot..?
I think you need to hold the power down for 10 seconds or something.
When its off you need to wait a few seconds and then hold the power button again until it wakes up.
I'm not sure if this is a quick fix hack or is there some longer / better solution
さんによる
I've tried that. Stays stuck in its loop. I've tried the boot menu. Stays stuck... But thank you.
さんによる
Ok.. I did find something that was related to - Samsung Galaxy A30 keeps restarting, Freezing Problem and Closed Unexpectedly | How to Fix? -
if you search that you may find a suitable answer
さんによる
@eureka is this what you were relating to :https://hrdreset.com/samsung-galaxy-a30-... ?
It is okay to add links into your comment or even to your answer. If iRobot "bites" again let us know :-)
さんによる
コメントを追加
1 件の回答
could be a bad battery or one with low charge. It may be shutting down after it tests the battery charge and finds it is below the shutoff level.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Not the battery, does with full charge. Thank you for your help.
さんによる
コメントを追加
回答を追加する
jenniferpinnell1973 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 254
