メインコンテンツにスキップ
The Dodge Dakota (called the Ram Dakota for its final two years of production) is a mid-size pickup truck from Chrysler’s Ram division (formerly called the Dodge Truck division). The second-generation Dakota began development in 1991, though they were not introduced until 1996 for the 1997 model year.
67回答 すべてを表示
Why did my window fall down when I slammed the door
Why did my window fall down when I slammed the door and won’t go back up on my 2004 quad cab
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Tried searching for Dakota forums? Owners share experiences, problems and answers. If your window is cable connected to pulleys, severe corrosion may have eroded mechanical parts along with window guides requiring removing the inner door panel for inspection.
さんによる
コメントを追加
1 件の回答
Your glass window fell down because there is a small guide like ledge the holds your glass window to go up and down and when you slammed it, it came off from the guide. Remove the inner sidings of your door and attempt to put it back in place.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Howard Hefele さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 45
