メインコンテンツにスキップ
モデル番号A1312 / Mid 2010 / 3.2 GHz Core i3もしくは2.8 & 3.6 GHz Core i5もしくは2.93 GHz Core i7, ID iMac11,3
382回答 すべてを表示
temperature sensor (TC0D and TC0P) shows -127°C
Hi,
my imac does not start mac os and shows a temperature of -127°C at the sensors TC0D and TC0P under Linux. i have already measured the sensor with a multimeter and it seems to be ok.
Maybe someone can help me to find the cause.
Thanks a lot :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
A negative value like what you are seeing is either, an unused sensor input, a bad sensor or the connection pathway is broken to the sensors input within the SMC logic.
Linux is really not the best way to diagnose your system. You should use either the CD/DVD diagnostics or the onboard diagnostics. Locate your original grey CD/DVD (grey disks) for the one with diagnostics. Or, see if the onboard works, restart your system and press the D key on your wired keyboard.
Reference:
TC0D & TC0P - Are not listed within your systems service guide or within the schematics so I think these are not used call outs.
You talk about not being able to start OS-X/macOS. Can you give is a better idea on what is happening (put the system back together and retest) If you remember describe what transpired when the system stopped working.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks it was only the hard disk broken...
well now an i3 became an i7 ?
さんによる
@fritz123 - Its a bit of work, but if you get the correct chip 2.93 GHz I7-870 you should be fine
さんによる
コメントを追加
回答を追加する
Fritz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 368
