メインコンテンツにスキップ
Valve Steam Controller, released November 10th 2015. Model 1001.
16回答 すべてを表示
My right bumper isn't working
I was playing a game and was pressing and holding this button a lot. Suddenly, it stopped working. I ran the diagnose on Big Picture mode and when I pressed it really hard it was detected, which led me to believe the problem was with the button piece and not the “sensor”. I haven’t tried opening it yet. How can I fix it?
Update (12/19/2021)
I opened yesterday and can say for sure now it’s the button.
I’m thinking the only way to fix this now is to 3D print another piece
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
9 out of 10 times its the sensor, not the button itself.
the only way youre going to fix it is by opening it.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
@madame can you post a picture of the sensor also? but i think i see what youre talking about
さんによる
@logixal I think I posted a picture as an update on this post. The piece of plastic broke, but the electronic part seems intact
さんによる
oooo i see, is the other part of it inside the controller? possible to superglue it? @madame
さんによる
コメントを追加
Most likely to fail component is actually the small, thin and uniquely shaped flange that activate the right and left bumpers. They are slightly paddle shaped and extend out from the oddly shaped bracket they are a part of on a narrow neck that appears extremely fragile. Their known longevity is a testament to the design of the whole controller as they seem to last far beyond what one would assume. When they DO break however, the bumper is totally useless and since they are only a piece sticking out of a larger whole (and Valve no longer makes these controllers or parts) to replace it is an exercise involving more parts and areas than necessary, cannibalizing another Steam controller, or desperately searching for an improbable find online. Crafting a replacement is far more likely an option and this has its own issues.. There is a youtube video where a guy uses a tape measure for its type of metal material as the source for the creation of a replacement... I recommend it if this is what you are dealing with.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kyogrefraga さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 27
今までの合計 266
