メインコンテンツにスキップ
Why can't I unscrew these screws on the volume rocker of my gameboy?
Below are pictures of those screws and the screwdriver I am using to unscrew them. Can you tell me what’s wrong if I am doing something wrong here?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
I am sorry, but you seem to be using the wrong screwdriver for the job. You seem to be using a tri-wing screwdriver on a triangle head screw. You will need a screwdriver that is the correct shape. Here is the correct screwdriver: https://www.amazon.com/Silverhill-Tools-...
P.S. If you want to get a whole set of different bits, you can buy a kit, too. iFixit’s are really solid, but there are cheaper kits on Amazon you might also like. Happy to reply to any questions you may have.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
If you are in an extreme case unlike me, then follow Jose's answer or buy a screw extractor. If not then wrap your screwdriver with tinfoil. Thank you for reading and thank you Jose for the help.
さんによる
@retrospeticus You're very welcome.
さんによる
コメントを追加
回答を追加する
Fuad さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 167
