My Xbox 360 E does not turn on
My Xbox 360 E does not turn on and nor show any light in the power button.
The power supply was checked and it’s Ok.
Where do I start my diagnosis?
I am by no means an expert but I would start by making sure that my Power cables leading to the board are okay, then possibly checking the Motherboards Power in for shorts and then moving on to using a thermal camera to look for excessive heat areas, then checking the chips with the most heat output for shorts.
このアンサーは役に立ちましたか?
Thank you for your response
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 85
