Why is my xbox overheating? (Red ring code: 4132)
This xbox has had quite a few problems. While it plugged in and turned on after getting it, the disc drive did not open or read discs. Today I finally took it apart, fixed the drive, and got it working, I made sure it could read games, and put it back together. After about five minutes of being on, it overheated, showing the two red lights on the front. I pressed the sensor button and eject button to get my error code, “4132” can anyone tell me information on what this code means or how I could fix it?
9 件のコメント
Can you take a picture of your Xbox 360 motherboard (just the top)? iFixitでの質問に画像を追加する方法
Andrew S さんによる
@o0mcnugget0o 4132 is a secondary code. Do you have a primary E-Code? The two red light error is triggered by either CPU,CPU or Ram overheating. You did check your fan, heatsink and thermal paste already?
oldturkey03 さんによる
Took the pictures you wanted, see anything unusual? @andrewsawesome
DJ Gunter さんによる
I haven't worked on an Xbox 360 before, how do I get the primary E-code? @oldturkey03
DJ Gunter さんによる
@o0mcnugget0o check on here on here It tells you how to get the e-code
oldturkey03 さんによる
4件以上のコメントを表示
