Some keyboard's button not function
Hello,
my name is Vincenzo.
I have a MacBook Pro. Some keyboard's button do not function.
Do you think it is a keyboard's problem?
Thanks
この質問は役に立ちましたか?
Hello,
Thanks
この質問は役に立ちましたか?
Which keys are you having problems with? Has anything been spilled on the keyboard? Here's how to take it out if you think you need to replace it: MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Keyboard Replacement
このアンサーは役に立ちましたか?
You probably just need to clean it, pop off those key caps and wipe with a wet paper towel.
このアンサーは役に立ちましたか?
Hello,
sorry for my English.
I think no problem if some keyboard keys do not work.
I do not know if it crashed or not liquid because the MacBook Pro should I buy.
Thanks for the links
Are you Italian? You can write your responses in Italian if that is so.
Yes.
I'm Italian....
Do you speak Italian?
Si
I have change my MacBook Pro keyboard and it is function correct.
Ho cambiato la tastiera del MacBook Pro e adesso tutto funziona alla grande.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,577
