メインコンテンツにスキップ
The Nexus One (also known as the HTC Passion and Android Dev Phone 3) is a smartphone from Google (manufactured by HTC) that runs the Android operating system.
Why isn't my camera / sensors working?
hello, im new here so please bear with me. so i've dropped my n1 a couple of times and it still worked, but now i managed to drop it like 22 inches on a carpet, (while it was charging) ok so form this my camera, flash,led charging thing on top and sensors/ proximity/ light are not working. i've managed to open the device 2 times and moved gently the connectors inside. still no fix. can please tell me what should i do? warrenty is no option..
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
6件の回答
ベストアンサー
The ribbon cable has most likely become detached causing the screen to go black during a call, your camera to not work, and/or the sensors to not work.
This link below shows the cause.
Symtoms will be:
1. Camera does not work
2. Green/orange led charge light does not work
3. Ambient light sensor does not work
4. Phone goes blank during calls and cannot be fixed without pulling battery
Cause:
The first ribbon cable of the logic board is unhooked/latched
http://android.googlecode.com/issues/att...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I'm facing a similar problem.. dropped my phone and now the Camera and proximity sensor are not working.. would appreciate some help!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I'm also facing a similar problem after I dropped my Nexus One phone from 3 feet on concrete floor.
Initially nothing worked. All the 4 touch controls, Proximity Sensor, Camera and trackball weren't responding.
Then I took backup and reformatted the phone. After reformatting, 4 touch controls and trackball started working.
So issue is with Proximity Sensor and Camera.
I installed an app from Android Market to test the working of Sensor and Camera, Reading in the app showed they are dead.
@Keith Fawcett : Thanks for your answer. Do you have access to some tutorial or Video which you have come across, which will help me fix this issue myself. If you can provide me something where and how to fix Ribbon Cable it would be great.
Thanks.
P.S: I have checked lot of Video on YT but most of them are for broken screen or broken power button. Didn't find any on this Ribbon Cable though
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Answer and pic.
cnblnt.blogspot.com
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Symtoms will be:
Cause:bold text
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Keith Fawcett is right. The ribbon cable has most likely become detached causing the screen to go black during a call, your camera to not work, and/or the sensors to not work.Promity.
My nephew and I opened my Nexus One and we were able to fix this issue. Here are some videos we used to open the Nexus One. Willy Castillo and Steven Vilchez from Managua, Nicaragua.
http://youtu.be/dcEspM1Dkzo (1/3)
http://youtu.be/WrSzdZSgkQc (2/3)
http://youtu.be/eiIn1ta2lb8 (3/3)
Nexus One Teardown (photos)
Other link to open Nexus One: http://www.youtube.com/watch?v=Mx3oRsWAQ...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
alex n さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 18
今までの合計 6,270
