メインコンテンツにスキップ
Help for Samsung televisions with model code LN32D403.
2回答 すべてを表示
My Samsung television keeps glitching out
My Samsung television keeps glitching out for years now. Today, it got worse, and the glitching was followed by a “Weak or No Signal” message. Why does this keep happening? Solutions are welcome.
My Samsung TV model is LN32D403T-MX5HAUSC-1009.0.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Hi,
What is the source of the TV signal, a TV antenna or a cable box etc?
Try enabling the digital noise filter setting in the TV and check if that improves the signal and resolves the problem.
If still no good and if the TV is connected to an outside TV antenna, check that the antenna is pointing directly towards the TV transmission tower so as to maximize the signal strength. Compare it to other antennas in your neighbourhood to get the direction.
If the TV is connected to an indoor antenna, you may need to boost the signal with an antenna amplifier (supplier example only)
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Gabi Salinas さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 70
今までの合計 704
