メインコンテンツにスキップ
The 2016 version of the Samsung Galaxy A3 budget smartphone (model number: A310F).
59回答 すべてを表示
Why does my phone say "moisture detected"when I plug my charger?
Details on bullet points because I will waffle I a para
•I have a charger that is a bit lose but works fine.
•Last night I kept my phone for charging but it would not charge,so I pressed harder which worked.
•Next morning I opened my phone's and it said it has to factory reset. I don't ha e much data on it so I allowed it .
•When I kept my phone for charge again,this time it said it has moisture in the cable or the port.
•What should I do to remove the moisture?Should I blow inside it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Btw I tested my charger on my friends phone and it works perfectly
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Sounds to me like the charge port may be bad, I've run into this issue several times and a charge port replacement always fixed the issue.
Phones can be weird especially since they have so much tech nowadays. Phones are most susceptible to moisture than anything else, taking it into the bathroom while you shower can cause moisture exposure or even damage. This may be what happened I'm not sure but the solution for sure would be to replace the charge port. Or replace the device.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for taking your time to.answer this
さんによる
コメントを追加
回答を追加する
HelloDude さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 689
