メインコンテンツにスキップ
Print documents and photos Scan, Copy, Print and fax
Printer won't recognize internet for email
My hp photo smart 7520 keeps telling me I'm not connected to the internet when I'm trying to scan in a document to email. I've tried everything I can think of to fix it. Is there anyone who can help me out here??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Those functions often rely on a expiring cert from a CA (certificate authority), which requires the firmware to be maintained a lot of the time to keep the certificate current. The problem with inkjet printers is they rarely update the firmware, but when they do often sneak in a “security update” to protect their bottom line (ink sales), especially within the last ~5 years or so.
In many cases, these devices block without an override - even on high end lasers. As a result, the function dies with the cert unless it piggybacks off of a PC. They usually lasted ~5 years just a few years ago, but the major CAs stop at 3 years with browsers considering anything older “expired” to force everyone on the same page. That function is dead, especially if everything else works over WiFi - the ePrint stuff is probably next to die. Time to scan it to a PC and eMail it the old fashioned way. I usually ignore it for this exact reason and do it the old school way, or find a machine that piggybacks off of the computer to do it to avoid the certificate problem. The application based method can have issues as well, but it’s often a helper tool to open your eMail client unless you use webmail.
Just because you do not use it doesn’t mean you’re wasting money - it’s free for the OEMs to add as it’s code (the cert costs them, but that’s a one time expense since they replace them every 18 months or so and abandon the old machines). It’s there for one reason - to woo consumers and get them to buy it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Karen McIntyre さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 127
