Sonos Connect won't light up when plugged in - no power?
Hello!
I have two similar devices, both with the same issue — a Sonos Connect and a Sonos ZP90.
Neither device will power on—when plugged in, the light on the device doesn’t come on, it won’t connect to the network and won’t operate (at least, so it appears). It seems like the device itself in both cases isn’t receiving power—I’ve tried multiple outlets and power cables to power the devices, but with no luck (so it’s the device in both cases.) Is it possible that there’s a blown internal fuse that I can replace, or a burned out power supply or something similar that’s replaceable? Thanks!
この質問は役に立ちましたか?
