メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
Charger port iPod touch 4
Hello everyone, how to replace the charger port on the Ipod touch 4?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
1件のコメント
i have the same problem but whats wierd is that if i plug the charger in it reboots from completely dead and then doesnt charge and shuts off cause there is no power
さんによる
コメントを追加
7件の回答
最も参考になった回答
You will of course have to totally disassemble the iPod. The dock connector is solder onto the board. You will have to do lots of soldering. You will have to un-solder two anchors and about 30 connections, they are very small and close to each other. So you have to take extra care not to shorten the pins out. After that you will have to resolder all those connections and the two anchors. Not an easy task, unless you are used to soldering small pieces. This video is not for a 4th gen but will give you an idea what you are up against. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Actually there's a very simple way to remove the old connector you using A heat gun. You can pick one up for about 25 or 30 bucks at a hardware store. Disassemble your motherboard from the rest of the iPod put it in a clamp and use the heat gun on that connector back and forth on the metal parts in the connector. When it gets hot enough, the solder will melt and the connector will kind of droop. When it does that, Tap lightly with a screwdriver and it'll fall right out.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You have to remove the old by desoldering the two screw holes with a desoldering iron and bend slightly. Turn board over and with a heat gun with a small tip evenly heat the 30 pin connector until solder has liquified. hold with a pair of pliers gently pull it away from board while moving heat back and forth over. make sure to protect other components from heat with heat resistant tape or aluminum foil. Reattach the the two screw holes with solder and then align all pins to correspond with the 30 pins on board. Turn board back over and resolder using a heat gun and solder paste or using solder and a iron. Check for any bridging before completing.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Will a charging pad work to fix this?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
:( It's happend to mine the charger port is like chipped i tried to charge it, it was charging suddenly it stopped and came off
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
hello ive jus dropped my ipod n the place where you put the charger in is broken, could you help me!?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
hi would you be able to fix my charging port or replace it on my i pod touch 4th generttion and if so how much would it cost me.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
andrewbezn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 23,498
