Should I replace my battery or just get a new one
My macbook air 8 years old has 846 cycles
should i get a new one or just replace the battery and go on
im putting a picture
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi:
If your Macbook gets hot or is showing signs of bulging, those are pretty sure additional indications the battery needs replacing. Please take especial care when replacing it not to risk piercing the battery case. No sharp tools. A ripped case can be dangerously flammable and can even explode. A good replacement battery kit will include proper glue solvent and the right tools needed to do the job safely.
Above all, please be patient with yourself. You’re doing a pretty difficult job. Take your time. If you get frustrated or upset at all, walk away until you’re completely calm before resuming the job. And please dispose of the old battery properly.
If you are careful, methodical, and use good replacement parts and instructions, you can do this successfully and for a reasonable cost. Good luck!
このアンサーは役に立ちましたか?
Kaan Can - Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see iFixitでの質問に画像を追加する方法
Your cycle count is still below the expected count of 1000. But Li-Ion batteries also go bad by age. If this is the original battery then it’s likely in need of being replaced.
このアンサーは役に立ちましたか?
Original battery
Thanks oldturkey03 and danj
i think i should replace it as battery doesnt last long
SO i am getting a new battery and tools
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 121
1件のコメント
KAAN CAN excellent choice. Follow the guide and you'll be okay :-)
oldturkey03 さんによる
