メインコンテンツにスキップ
Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
My vcr won't play tapes
I bought a Emerson vcr to clean my moldy tapes and when I got home to try and see if it worked it would not play the tape (I tried multiple tapes) it won't fast forward nor rewind and when I tired to see if the motor worked manually it did but it won't work when I put tapes in it also shuts off after seconds of putting a tape in
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
When my vcr plays cassettes that have been taped in Ep mode, the picture is fuzzy and barely detectable. Why?
さんによる
The tracking is not working right ir the silver wheel has dirt on it that comes from playing tapes. First I'd try cleaning it with 91% ipa(alcohol)
さんによる
コメントを追加
1 件の回答
ベストアンサー
You will need to dive into it. but usually you threw or snapped a drive belt. there is usually at least 3 different ones possibly more.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I watched several YouTube videos and I check the belts (mine only seems to have one, if thats normal) it looked fine... I don't know if something is broken or caroted and the inside looks pretty new
さんによる
does it FF/RW tapes? with the cover off does the big silver with lines wheel keep turning?
さんによる
コメントを追加
回答を追加する
Homer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 1,030
