メインコンテンツにスキップ
The all-new GMT900 generation of the Silverado/Sierra arrived in the last quarter of 2006 as a 2007 model. It features a redesigned exterior, interior, frame, and suspension as well as a power increases on certain engines.
18回答 すべてを表示
Why do I have power but wont crank or turn over
Why do I have power but vehicle wont crank or turn over
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
this could be a few things. Your ignition switch, starter relay, or starter. Or the wiring to them or ground. You didn't post the year, and it appears things move around a bit fuse- and relay- wise in this year range. You'll need a multimeter or voltage tester to do this. Locate the starter relay (should be in the fuse box in the engine compartment) and test each plug where a prong on the relay goes in. One will have power without doing anything. If it doesn't, then locate the fuse for the starter. If it does, have someone try to start it while you test all the prongs that didn't have power until you find if another gets power while trying to start. This should show the ignition switch is doing its thing. If nothing gets power, then ignition switch likely the culprit. If it does, replace the solenoid, and go underneath to where your starter is. Have them try to start it. Check if your starter is getting voltage. If it is, starter is most likely toast. If it isn't, then the solenoid is the culprit. There might be better/easier ways to test all these but I don't know them.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You could also have a grounding issue or a bad ECM. I've experienced both with this model truck.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Mine ended up being the 40 amp stater fuse
さんによる
コメントを追加
回答を追加する
Chris Stack さん、ありがとうございました!
統計データ:
過去 24時間: 16
過去 7 日: 70
過去 30 日: 323
今までの合計 7,652
